The T.P.S in new change it anyway it did the same just put a timing chain on set 10degrees BTCIf memory is correct a 90 MPFI and it may be your throttle posion sensor or you may be out of time. When it's warmed up what does it idle at?
Are you sure you aligned everything back up properly when u put on the new timing chain. Also when you dropped the dizzy back in are you sure you had #1 cylinder on compression stroke not exhaust . Another thing maybe are your wires in correct firing order hey anything can happen just askin.... well good luck ....The T.P.S in new change it anyway it did the same just put a timing chain on set 10degrees BTC
