power problem on a full size 1990 bronco
cody12
OK when i turn the key it will rollover like 1 or maby 2 times then stop and it sounds like a dead battery but the battery is good then i checked all the connections on the batter they are all good then i thought it was the starter but i had it checked is good then i went to the starter solenoid and cleaned all the connections there and it started but i went out about an hour latter and it wouldn't start so i cleaned the solenoid connections again and it wouldn't start. if you have any ideas help would be greatly appreciated
digs
