power door locks
rubberdust
Henderson NV
anybody know does the power door locks on a 95 have a relay in the system. Every once in a while they go crazy locking & unlocking, if I pull the fuse it will stop & when I reinstall the fuse it may be fine for days. I've traced the wires in both doors & the wires all look good & it never blows the fuse like I would expect if it were shorted out.
I can hear something clicking up under the dash even with the fuse pulled when I hit the door lock switch. I'd live without the power door locks but the same fuse runs the rear window.
Well, if the system has a remote key lock system, factory or aftermarket, it will have a relay.
rubberdust
rubberdust
Henderson NV
thanks
didn't a keyless remote with it but that makes sense, it has a theft light among the idiot lights & today out of the blue the horn started blowing & that was flashing on & off until I got in & stated it.
rubberdust
rubberdust
Henderson NV
FYI
This has amazed me but I replaced the ignition switch (tumbler) which was also junk.
The problem has gone away & the locks haven't had any issue since.
go figure
FYIThis has amazed me but I replaced the ignition switch (tumbler) which was also junk.
go figure
23868[/snapback]
Who'da thunk :blink: Never would have made a connection with that one since the door locks are a hot at all times function. I would have expected the remote entry module :ph34r: /emoticons/[email protected] 2x" width="20" height="20" /> .
Wihill
