jonnybravo101
Whazzup forum. >- I am not new to the site, but new to starting a topic. Okay I'm just new. Anyhow, I have seen alot of helpful tips for the rear window problem many have been having. After reviewing several of them I finally decided to try and fix mine. No can do. I bypassed that connection that doesn't allow you to use the rear window when the tailgate is down. Still no up down rear window action. From there I traced the wiring to a gray male female connection below the rear window inside the tailgate. I disconnected that, and ran a jumper from the battery to the plug going to the motor. SUCCESS! /emoticons/[email protected] 2x" width="20" height="20" /> Window goes up window goes down. However when I reconnect the two,turn the key,and press my rear window button, nothing happens. FAILURE! I am getting 12v at the gray plug coming from the bypassed connection. But when I connect the two gray plugs, have my gal press the button on the dash, and check voltage at the gray plug I get almost 1volt basically nothing. Just a faint noise coming from the rear window motor. Possible short? I don't know. Any troubleshooters out there? Trying to cover everything, sorry about the long post. 1995 Bronco XLT 5.0L 305
