Possible Computer Issue
1989 Bronco 4x4 XLT
I have 1989 Fullsize with a rebuilt EFI 302 we just put in. We are trying to break it in right now. It starts great when cold but after it warms up and we cut it off it wont restart??? We are getting gas to the injectors and getting a spark at the plugs when it doesn't start. It starts fine when cold and I can restart it multiple times when its cold. For some reason it wont start when its warmed up. I read somewhere else that those are the symptoms for the computer going out? We have replaced a whole lot of stuff in the ignition system already Ign. Switch, Coil, Starter, Starter Solenoid, PIP/Stater in the distributor, ICM, New Wires, Cap, Rotor. Now we replaced some stuff in the fuel system also New Tank, Sending Assembly, and the Filter. I think the computer is not getting the Air/Fuel mixture right for when it is already warmed up. We have the timing set perfect! It runs so good. We just can't get it to fire up when warm. Is there any other ignition components that could be failing? Or could there be something that is getting too hot like being too close to the motor? Could it be a short somewhere. I unwrapped the engine wiring harness during the rebuild and looked for nicked wires that could short and couldn't find anything. I also did install the Ignition Switch correctly. Which is what we thought was the problem(installed wrong). Any help would be appreciated.
Ken
As long as the Bronco had a 302 EFI in it as built, you're ok so far.
Try a Self Test by my pal, BroncoJoe19
An assistant to write the info is helpful
heat the engine up; idle until temp gauge is in normal range you usually see
and when it warms up; shift thru all gears incl Reverse anyway.
Then turn off all accessories/lights, etc.
Make sure A/C is off and transmission is in Park (automatic)
Do Key On Engine Off (KOEO) portion first.
The engine temperature must be at least than 50°F for the KOEO portion & more than 180°F for the KOER portion.
Look Codes up in my broncolinks.com site using the new Search function if in a hurry today.
Search for:
DTC (space) (insert code)
And Post em here according to
KOEO
& KOER
A GUESS is the TFI's Hall Effect (aka Profile Ignition Pick-up (PIP) Signal, Stator, RPM)
Somre resources;
Testing, Overview & Diagrams; "...The Thick Film Integrated (TFI-IV) ignition system uses a camshaft driven distributor with no centrifugal or vacuum advance. The distributor has a diecast base, incorporating a Hall effect stator assembly. The TFI-IV system module is mounted on the distributor base, it has 6 pins and uses an E-Core ignition coil, named after the shape of the laminations making up the core. The TFI-IV module supplies voltage to the Profile Ignition Pick-up (PIP) sensor, which sends the crankshaft position information to the TFI-IV module. The TFI-IV module then sends this information to the EEC-IV module, which determines the spark timing and sends an electronic signal to the TFI-IV ignition module to turn off the coil and produce a spark to fire the spark plug. The operation of the universal distributor is accomplished through the Hall effect stator assembly, causing the ignition coil to be switched off and on by the EEC-IV computer and TFI-IV modules. The vane switch is an encapsulated package consisting of a Hall sensor on one side and a permanent magnet on the other side. A rotary vane cup, made of ferrous metal, is used to trigger the Hall effect switch. When the window of the vane cup is between the magnet and the Hall effect device, a magnetic flux field is completed from the magnet through the Hall effect device back to the magnet. As the vane passes through the opening, the flux lines are shunted through the vane and back to the magnet. A voltage is produced while the vane passes through the opening. When the vane clears the opening, the window causes the signal to go to 0 volts. The signal is then used by the EEC-IV system for crankshaft position sensing and the computation of the desired spark advance based on the engine demand and calibration. The voltage distribution is accomplished through a conventional rotor, cap and ignition wires. GENERAL TESTING - Spark Plug Wire Resistance Whenever the high tension wires are removed from the plugs, coil, or distributor, silicone grease must be applied to the boot before reconnection. Use a clean small screwdriver blade to coat the entire interior surface with Ford silicone grease D7AZ-19A331-A, Dow Corning #111, or General Electric G-627. Use spark plug wire removal pliers, or grasp firmly at the boot (not the wire itself) and remove the wires from the plugs, then remove the distributor cap. Measure the resistance through the distributor cap at that end. Resistance on these wires must not exceed 5,000 ohms per foot. Do not pierce any ignition wire for any reason. Measure only from the two ends. Adjustments - The air gap between the armature and magnetic pick-up coil in the distributor is not adjustable, nor are there any adjustment for the amplifier module. Inoperative components are simply replaced. Any attempt to connect components outside the vehicle may result in component failure. - TROUBLESHOOTING THE TFI-IV SYSTEM; After performing any test which requires piercing a wire with a straight pin, remove the straight pin and seal the holes in the wire with silicone sealer. Wiring Harness - Disconnect the wiring harness connector from the TFI module; the connector tabs must be PUSHED to disengage the connector. Inspect the connector for damage, dirt, and corrosion. Attach the negative lead of a voltmeter to the base of the distributor. Attach the other voltmeter lead to a small straight pin. With the ignition switch in the RUN position, insert the straight pin into the No. 1 terminal of the TFI module connector. Note the voltage reading. With the ignition switch in the RUN position, move the straight pin to the No. 2 connector terminal. Again, note the voltage reading. Move the straight pin to the No. 3 connector terminal, then turn the ignition switch to the START position. Note the voltage reading then turn the ignition OFF . The voltage readings should all be at least 90 percent of the available battery voltage. If the readings are okay, proceed to the Stator Assembly and Module test. If any reading is less than 90 percent of the battery voltage, inspect the wiring, connectors, and/or ignition switch for defects. if the voltage is low only at the No. 1 terminal, proceed to the ignition coil primary voltage test. Stator Assembly and Module - Remove the distributor from the engine. Remove the TFI module from the distributor. Inspect the distributor terminals, ground ****** and stator wiring for damage. Repair as necessary. Measure the resistance of the stator assembly, using an ohmmeter. If the ohmmeter reading is 800-975 ohms, the stator is okay, but the TFI module must be replaced. If the ohmmeter reading is less than 800 ohms or more than 975 ohms; the TFI module is okay, but the stator module must be replaced. Repair as necessary and install the TFI module and the distributor. - Primary Circuit Continuity; This test is performed in the same manner as the previous Wiring Harness test, but only the No. 1 terminal conductor is tested (ignition switch in Run position). If the voltage is less than 90 percent of the available battery voltage, proceed to the coil primary voltage test; rotary armature has open areas called windows and tabs called vanes..." miesk5 NOTE; stator is a Hall Effect device, which uses a magnetic field. It sits under the distributor cap and picks up a signal from a wheel with teeth. (miesk5 NOTE; this wheel is a rotary armature that has open areas called windows and tabs, called vanes). The wheel has the same number of teeth as cylinders in the engine and moves at the same speed as the distributor and camshaft. If you have a V8 then the wheel has eight teeth; seven teeth are the same and one tooth is smaller to identify cylinder #1. As the wheel spins with the distributor is breaks the magnetic field of the hall devise generating a sine wave. This sine wave is called the raw Profile Ignition Pickup (PIP) signal and indicates the engine status at 10deg. BTDC. Now some people think the TFI is responsible for this, but that is incorrect; the PIP signal passes thru the TFI unaltered to the computer.(by Ryan M)
Source: by Chilton via autozone.com
digs
