posi????
88horse
madera
ok im tired of getting stuck will a a rearend out of a ford explorer???
my buddy has a stock explorer and can go threw some stuff that :blink: i cant and vice versa
help!!!!!
thanks
Krafty
Ontario Canada
what year is the explorer? plus the explorer is based off the bronco 2 I doubt the axle would be wide enough or beffy enough.
Krafty
Ontario Canada
Unless you meant an F150 Explorer, and likely it will have the same axle you have, just open diff. but what you can do it take it if its the same and tear it apart and put a locker in it. if its an 8.8 then there will be a rear diff cover. if its a 9" then the whole *** has to come out through the front.
seansz28
