POS B2 wont go over 55mph
walterm
Baton Rouge, La.
rarely it'll go 58 with it floored. whats wrong with it? 2.9v-6, 5 speed, 4x4. oh, its an '86
nIf the cat is on it its probably plugged a buddy of mines jeep did that took it off and you could hear the chunks rattling around in it . :D /emoticons/[email protected] 2x" width="20" height="20" />
mjbronco11
i have 8911 mine goes over 55 but mine slips outa gear when im going up hill in 4wheel drive any ideas
mjbronco11
Prob. need a bit more info.... :-B Are you sure you're in 2 wheel drive/ high range..? Does it have a tach.?
Engine condition?, etc. >
24209[/snapback]
if you remove your cat will that make your engine run better
cowboydan
I gave up, costom built the engine, and now I'm dropping in a diesel. ***** gas!
25740[/snapback]
diesel isn't much better, price wise. i'd go with 5.0 swap/propane...
now if you're talking diesel/propane, then i might use a diesel
digs
