We just replaced the 289 with a 302 in my '67. We had it running tonight, got the timing set, set our idle mixture, and it seemed to run fine... However, we are having serious trouble getting it to start up.. Even with the battery jumped, charged for a while, anything, it seems to barely get the engine to turn over... It turns it, just very slowly, like 1 sec per revolution...
Here's what gets me.. The battery check at advance auto parts said good, still does it.. And although it does it most of the time, every now and then, it'll pick up and just start cranking a lot faster, like it normally should (which is how we got it started to set the timing). Finally, we pulled the ground off the block, and there were small sparks from the ground to the block (that one really puzzled me).
Any ideas? Anybody know of a bad "something" that will charge the engine block (like a bad starter relay or ignition coil)? Thanks a bunch.
-Will
-Will
