yes, that tranny will fit. its an E40D, a respectable slush box. the only issue i can forsee is the fact that its also the longest trans for ever made, so your driveshaft angles are going to be crazy steep in the back, and very shallow in the front. you'll also have to fab up a new xmember to support it if i were you, i'd look for a C4 or C6 transmission. all ford small blocks share the same bellhousing pattern, so as long as its a small block and not a 351M or 400M, the trans will fit. and AFAIK, all ford t-cases shared the same bolt pattern too
