pitman arm
Kaine
Las Vegas Nv.
looking to increase lift on my bronco when we swap in the solid axle. now have 6in of susp, but will have close to 10 when axle gos in. where do I fine a pitman to work with the new lift?
The best source of dropped Pitman arms I've found is from Skyjacker. I would suggest waiting until you do the SAS and determine what your final lift is, along with any changes to the asteering linkage. I am currently using a SkyJ dropped arm from my 6" ttb lift kit in my setup from the 88 F-350. Howver, I do not have any more lift thsn what was gsined from the front crossmember, which is about 4". JSM84
Ford644
