my 82 rear end leaks every where it can, pinion seal, axle seal, and brake cylinders I'm gonna replace evrything. My question is can you pull the driveshaft & yoke and change the seal or do you hafta crack the whole thing open? I think I have a 9" limited slip I dont know the ratio. the tag nos. are, top line , WFE ABC 1JO1 bottom line 3 L00 9 S323B. also can you change radius arm bushings without loosening at the front axle? thanks for any help
