Performance Chips
Jersey Dave
I purchased a 96 bronco yesterday with a 302 in it I was trying to see if there was a performance chip or what the easiest was to get some added performance would be. As of right now it has a siezed block that I need to pull and see why it seized. I might get away with just doing a crank but if not will a 351 bolt to the same trans. I am looking for somewhat affordable power and maybe even a new block with more power I know the stock 302 has 199 horse and the stock 351 only has 210 for that year. Does anyone know a place I can find an affordable block with around 300 ponies or even a rebuild kit that would give me around that much from either engine thanks
Hey Dave,
Welcome.First avoid the cheap ($69.00) chips that are advertised and are connecteed at the IAT sensor. They are junk and do nothing.
A 351 about the same year should bolt right in.
If you can stand with the truck being down for awhile, I would rebuild the 302. Search or better call someplace like Summit or Jegs and tell them what you have and what you want and they can get you the parts, ( cam and components , headers, exhaust, t bodies, intake, etc.0 that will give you what or close to what you want.
A 300 horse crate engine or shortblock or would be more expensive.
Good Luck
yo Dave,
I replied on the Chip in your other thread here @ http://broncozone.com/topic/23577-new-memeber-from-jersey/page__pid__123004#entry123004
As you know Speed = Big $$$
Here is a good article by Ryan M at http://oldfuelinjection.com/?p=9
& Chips/Tweecer
http://oldfuelinjection.com/index.php?p=77
You can look through my site for various related parts upgraades; such as
Camshaft
http://www.broncolinks.com/index.php?index=157
Ryan M advises; Best 5.0L/5.8L (302/351) Roller EFI cam:
89-95 Mustang 5.0L **
Ford Part numbers: E8ZE-6250-CA / F1ZE-6250-AA / F4ZE-6250-DA
* Advertised Duration: 276 / 266
* Duration at .050 in.: 214 / 210
* Gross valve lift: 0.444 / 0.444
* Lobe separation: 115°
Cylinder Head & Valve, Push Rod
http://www.broncolinks.com/index.php?index=160
such as
GT-40 & GT-40P Marking pics; "...Here's some pictures showing the markings on the GT40 heads. The GT40 heads were used on the 5.0 Cobra Mustangs, and the 95, 96 and early 97 Explorers. I've heard that all 97's had the GT40 heads, I don't know when Ford switched to the P heads. The GT40 heads have GT cast into them in several places, also if you can see the end of the head the GT40 heads have three bars cast into the end, the GT40P heads have four bars cast into the head..."
Source: by Kenny B (Ken B, Kenny's 94)
mindy
