pcv help!
duttysean
tallahassee, fl
Pardon the newbie question, but I can't find the PCV valve in my Bronco, I know it's somewhere on the back of the upper manifold, but I can't seem to find the right angle to see it. I've tried looking at it from every direction, including from under the truck, can anyone help me figure it out?
Yardape
Alberta
Should go from the back of the upper intake to the passenger side valve cover. Have a look and if you still can't find it I go venture outside and dig my way down to my bronc through the snow
bobstrat
beautiful trenton, n.j.
am i missing the obvious? miesk5 why does the stock location cause failure in 5 and 8? this is the first ive heard of that. do i have cause to be concerned with having mine in the stock location?
yo Bob,
According to a pal in another area; "due to PCV breakdown and carbon build up in the #8 cylinder. Ford believes that by moving it (he is referring to the PCV valve vacuum supply hose) to it's new location, it will not be as likely to load up and fail."
In any event, Ford did change the routing in 94.
Here is the original Non-Ford info source for this, where only #8 is cited;:
Source: by fourstarengines.com
"Failure of the #8 piston or the #8 rod or rod bearing in Ford 5.0L, V-8 gas engines
Applications affected have been in 1987-1993 pick-up trucks and vans. After discussing the situation with several installers, the problem has been narrowed down to the PCV system.
Solution:
During engine installation, reroute the PCV valve vacuum supply hose. Follow these steps:
Plug the 3/8" (pipe) thread hole in the rear of the plenum where the PCV valve hose is connected.
Drill and tap a 3/8" pipe thread hole in the center of the plenum and thread the PCV connector into it.
Reconnect the PCV valve vacuum supply hose to the new location.
Be sure the drain hole in the baffle is open. The baffle is under the PCV location in the valve cover.
Installers who have rerouted the PCV system and opened the baffle drain hole have not reported any #8 cylinder failures.
CONTACT US for more information or call 1-800-777-2067
Back to Tech Tips "
Staff online
79brnco
