Ski
Does anyone know what O2 sensor is Bank 1 Sensor 1 on a 96 bronco? It is just too expensive right now to buy 4 sensors! I bought one and just want to swap out the bad one. Also how can I reset my check engine light???
bank 1 sensor 1 should be left front before the cat (possibly in the manifold or in the y-pipe, i'm not sure)Does anyone know what O2 sensor is Bank 1 Sensor 1 on a 96 bronco? It is just too expensive right now to buy 4 sensors! I bought one and just want to swap out the bad one. Also how can I reset my check engine light???
So drivers side off the manifold? I will try it. Would disconnecting my battery terminal reset my check engine light?? Also any ideas on how to remove it? it seems to be stuck pretty goodbank 1 sensor 1 should be left front before the cat (possibly in the manifold or in the y-pipe, i'm not sure)
try using universal sensors (using the old connectors and heat shrinking the wires together)
any autozone with a code reader CAN shut off the light (although not supposed to), or just pull the positive battery cable.
good luck
looks like its in the y-pipe down towards the cat.So drivers side off the manifold? I will try it. Would disconnecting my battery terminal reset my check engine light?? Also any ideas on how to remove it? it seems to be stuck pretty good
