overheating
bidibronco
Norfolk Va
I have a 94 Bronc' with the 351w in it. I've replaced my timing cover gasket twice now and it still has a leak in it where the water jacket is on the passenger side? The first time it was leaking and I replaced it I figured I just didn't tighten the bolts down good enough, now they're on their good and the leak still persists. Like I said, I've replaced the gasket twice? Anyone have any suggestions? thanks....
jstout1976
ATHENS GA
i know you did this but did you make sure that the old gasket was all scraped off also did you inspect the cover for any cracks just some suggestions let me know what you find thanks justin
Justbust1n
walkertown
if you find all of the gasket was removed ... it might be on the block unfortunatly and you might have to do some personal mods to the timming cover if thats the case which hopefully it isnt ... but if it isnt the gasket or the timming cover itself it has to be the block
