overhead light
mhblackburn
Hello everyone. New to forum and bronco ownership. Have a 90 FSB 351W Eddie Bauer that I'm restoring. Generally good condition. Radio didn't work when I bought it; replaced it with aftermarket, which still didn't work. culprit turned out to be one of the 2 15A fuses that runs the stereo, companion/dome lights. Radio now works fine, but overhead lamp will not turn off. Fuse now removed(to my dismay-I love my music!) to keep the battery from draining. Has anyone had a similar problem, or know a solution that will get my stereo up and running? Thinking it might be a door latch issue. Any help would be appreciated.
Bronc76
had similar problem with mine, ended up being courtesy light switch assembly.
stusainte
01085 Ma.
Had the same issue with my95 check your door switch I had to unscrew the the switches and found the wires were corrodid after cleaning them up havent had any issues since Good luck
rcarm74
