Online IPB
WileE7
Does anyone know of a site the has an IPB (Illustrated Parts Breakdown) for Bronco's I need to remove my fender and rear quarter panels there is nothing in the CHiltons about it
Take a look at LMC Truck, they now have their catalogs online. Removing a front fender is very straight-froward, though. A matter of removing all of the underhood parts attached to it, then the bolts/screws at the core support and cowl. On the 87-up models, take off the headlight assemblies to access those screws. Removing rear quarter panels is alot more involved, since they're spot-welded to the body. Get a spot-weld cutting drillbit and a SawZ-All to work after pulling the gas filler tube, tire carrier and taillights. JSM84
Planning to keep the truck ? If you are I would *strongly* advise looking into a set of factory manuals from Helm Inc. Helm published of all of the major mfg's and there is literally nothing that compares to them for completeness & clarity. None of that "assemble in reverse order" that you see in Chiltons & Haynes and there are numerous exploded views with part numbers. Anyone who's ever had a set will confirm this, if you're going to be keeping the truck & doing more of your own work then invest in a set.
seansz28
