broncokenny
Ken Emerson
Ok after pulling shaft and distributor,so I could change module.I changed waterpump,thermo and
coil while I had everything apart.Got shaft out of oil pan,put everything back together put it at TDC,then followed the way I had spark plugs to dist. prior to changing everthing.When I tried to start still sounds way off wont start,infact the solenoid stuck and it kept turning over on its own!!!Even after I turned key off .What
did I do wrong?????? Signed sunday mechanic
