OK everything is back together,but still wont start
broncokenny
Ken Emerson
Michigan
Ok after pulling shaft and distributor,so I could change module.I changed waterpump,thermo and
coil while I had everything apart.Got shaft out of oil pan,put everything back together put it at TDC,then followed the way I had spark plugs to dist. prior to changing everthing.When I tried to start still sounds way off wont start,infact the solenoid stuck and it kept turning over on its own!!!Even after I turned key off .What
did I do wrong?????? Signed sunday mechanic
"----put it at TDC---"
Are you sure it's on compression stroke..? (not exhaust)
"----solenoid stuck and it kept turning over on its own!!! Even after I turned key off ---"
Did you break a mirror...? Not having much "good" luck....
Anyway, seperate issue.....hot/bad solenoid -or- faulty key-switch.
Ralphdb
Lakeland Florida
I ran the Plug wires on my son's 88FSB 351 it ran like crap. no power but it did run. when I rewired it like a 302 which peed him off it ran great. had a lot of module problems with it.. it would run great until it warmed up then shut down and not start until it cooled down . It was the module a crack in the circuit board...
bigtrux
Murrieta,CA
SOUNDS LIKE WERE HAVING THE SAME ISSUE I GOT A 93 WITH 351W BRAND NEW MOTOR STILL WON'T START... EYOU FIGURE IT OUT OR I DO WE'LL HAVE TO LET EACH OTHER KNOW. I'VE RECHECKED EVERYTHING I'M GOING TO REALIGN TDC AND THE DISTRIBUTOR.. AND CHECK COIL I'M GONNA START ROBBING PARTS OFF MY BUDDIES TILL I FIGURE OUT WHAT IS WRONG... LOL
broncokenny
Ken Emerson
Michigan
My 88 is up and running fine ,but 100.00s of dollars later I still have the **** problem,they told me it s my rear end.Im still afraid it could be more than that.But any way get it toTDC then fine your firing sequence.
Start at # 1 plug and wire and go counter clockwise around cap.I have sequence in my haynes manual if you
dont have it. <)
