oil leaking on top of the timing cover
diymirage
hey guys
i bought a 87 bronco today, with a 351W in it but it is leaking oil on top of the timing cover
the engine has been rebuild with aluminum heads, eddy airgap RPM intake and a wilder cam
my first thought would be a bad seal on the china wall (possibly due to a lack of PCV system)
does this sound like a good assumption or should a look at the actual timing cover ?
Congrats!
I replied to the possible  timing cover leak in your other post @ http://broncozone.com/topic/25870-oil-leaking-on-top-of-the-timing-cover/?do=findComment&comment=136084
And another on the grey sealant @ http://broncozone.com/topic/25868-one-bronco-with-two-vins/?do=findComment&comment=136086
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
In pop up,
Click, My Profile
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Keep each post limited to one issue.
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line ordersTo get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @ http://www.revbase.com/BBBMotor/Wd
GREAT LUCK WITH THE 87!
