MUDBUG
i have a 351W 5.8l that has oil comming out of my dip stick. has anyone heard of thei and or know a solution to this problem? thanks
thanks i will try it out and see what it does.start with replacing the pcv valve, it maybe restricted,causing an excess in oil pressure.
no the oil looks fine, it is just not staying where it is sould be.Take a look at the oil... is it foamy? or milkshake of creamcycle looking? If so, you may have a blown head gasket or cracked block allowing coolent to mix with your oil.
