OD cancel button works but lamp doesn't
buck45
Headin down south to the land of the pine
93 5.0 E4OD. My OD cancel button works fine (I can toggle in and out of overdrive), but the indicator lamp doesn't come on. I'm thinking that the button is good and the lamp inside is burned out, but before I buy a replacement part does anyone know how I might test it?
buck45
The OD cancel button and lamp is on the end of the shifter. I believe the lamp is built-in to the switch, but before I pop the cover and pull it out I want to try to find out a little more about it.
yo;
Buy a new LED/Switch From da Zone's SPONSOR; Transmission Control Indicator Light (TCIL) Button, LED & Cap (replacement part) with PIC
http://broncograveyard.com/bronco/i-37018_...ton_and_cap.htm
Item #37018 - New
1992-96 Ford Bronco
1992-96 Ford Truck
This is the overdrive button on the end of the column shifter, comes with small cap.
Our Price: $10.00
Transmission Control Indicator Light (TCIL) Malfunction due to a faulty O/D Cancel Switch/ LED; Part #F58Z-7G550-A
Source: by ATC-Distribution Group Inc. atcdg.com via web.archive.org http://web.archive.org/web/20020113193545/...ns/bull_135.htm
Pry it off with a thin flat screwdriver or pocket knife blade; it is spring-loaded so hold the round end trim piece while poppin' it off.
