Np205 Staying In Gear
BuckWild79
Virginia Beach, VA
My Np205 will not come out of 4 wheel drive. I took the boot off and had a good look when someone was driving the other day and saw that the front driveshaft would only start spinning once you hit about 15 mph in 2h. 4h it spins immediatly when you move off course. In neutral the front shaft spins immediatley when put in neurtal on the case. I took the front shaft out and drove it around. Rear driveshaft snapped the h joint same day I dont if the case had something to do with it but I put the front shaft back in and took the rear out and drove it home.
Baltimore773
