As WILEEC mentioned.
You need the VSS signal input to drive the PSOM, as well as the PCM, E4OD (4R) and if equipped, the cruise contol
The VSS signal travels from the VSS through a fewc connectors to the 4WABS Control Module and then to the PSOM and on to PCM/Tranny/CC via more connectors; as show in this;
4WABS Wiring Diagram & Connectors in a 93, 94-96 are similar Source: by Steve
http://www.supermotors.net/registry/media/170517_1
To bypass the 4WABS module @ it's harness's connector & feed the ABS signal directly to the PSOM,
In Module's connector (harness side); jumper LG/Bk to LG/Y, and R/Pk to O/LB..."
pic of the connector and jumpers
by Turbo Ghost at
http://img.photobucket.com/albums/v252/turboghost/ABSConnectorw-jumpers.jpg
Also, many Wiring Diagrams in a 95 from EVTM (Click Next to view more)
Source: by SeattleFSB (Seattle FSB) at
http://www.supermotors.net/registry/media/859597
