89 with TFI-IV stopped suddenly after running for only a minute or so. Ran the previous day and before that with no problem. Now it won't start. Appears to be ignition problem.
Checked with test light at Tach terminal to ground per Haynes manual, and light flickers rapidly, (as mentioned in Bebop's posts), but does not appear to flash as Haynes suggests. What I'm seeing may be flashing, but that's not what I'd call it.
Anyway, no spark at coil. Coil resistance is supposed to be 0.3 to 1.0 ohm primary, and 8000 to 10000 ohm secondary. I get 0.53 primary and 7469 secondary. The secondary is a little low, but I'd normally not consider that bad. Is it bad based on those resistance readings?
This Bronco is kept outside, and had quite a bit of snow under the hood after a wicked lake effect snow storm with 30+ mph wind. This isn't the first time I've had a bunch of snow under the hood. but wonder if the snow is causing the problem. It didn't run long enough to warm up and melt any snow before it stalled, so it wouldn't have gotten wet.
I've never tried the self-test code readings. Might there be a code for this problem?
Any ideas? Thanks.
Any ideas? Thanks.
