302 new project, wired warnesS ran fine. then covered and tie wrapped wiring , mounted coil,was hanging loose, switched main ground wire on eng block. Now it turns over but wont start. only .7 volts at 3 required wires at eec, should have 12. fuel pump does not go on.
