ryanbass2
Hello all,
i rebuilt a 351w for my 81 bronco about 3 years ago. i had it sitting in a garage since then i just put the engine in and i get no oil pressure when i start it. i can manually prime the engine with a drill but it has to be at full speed to start getting pressure like 2100 rpm out of drill which would be about 4200 rpms of engine speed. at that speed i can get 40 psi of oil pressure. then i imediatly drop in distributor and start engine oil pressure goes to 20psi the drops to 0 and lifters start to make noise.
/emoticons/[email protected] 2x" width="20" height="20" />
heres what i have checked so far.
pickup tube is good and gasket is there
oilpump is brand new and has gasket and releif is not stuck.
All oil galley plugs are in
all bearings are right size
dist engages rod for pump fully
oh and when i rebuilt the engine everything was replaced with new parts except for crank and rods.
i dont know what to do now im puzzeled :huh:
