no fuel threw injectors
ctryboysurvivor
pueblo colorado
have spark, have fuel to rail, replaced fuel pressure reg, still no fuel . will start and run for a fews seconds just fine with a gas soked rag over the intake. there is elec. on wires at injectors. was running great before i pulled dash apart . dash is to remain apart ,turning into a truggy.not to sure what happened and i can not figure it out have done all the checks on fuel and ignition .all is good just fuel wont push though injectors. the injectors cant be bad the thing was runnin great just a few hours before.i know the injectors fire by a pulsing ground from the eec were is this ground if i nocked that off that could be the prob. but i am beginning to beleave my eec is bad.if anyone can give me some insight on my prob i would greatly appreciate it . please dumb down replies though i hate some of the text book replies.unless no other way to explain.pics to explain were to locate would be nice as well.thanx
What year?
Have you pulled Codes yet? KOEO for now
a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19 @ http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Next would be to do the simple FI Test shown below and then fuel pressure test
If it is 92-96 then look at Tan wire that is common to all injectors an travels back to EEC
if a 90 and some prior years; it is Tan/Orange and goes to EEC pin 58 or 59 depening on injector number;
89 is Tan/Orange and Tan/Red
See EEC Connector Pin Diagram & Overview
Source: by Fireguy50 (Ryan M) at http://fordfuelinjection.com/?p=3
EEC Connector Pin Outs, Bronco & Ford Truck & Van: 4.9, 460, 5.0, 5.8; miesk5 Note, see his Connector Pin Diagram Link above)
Source: by Ryan M (Fireguy50) at http://fordfuelinjection.com/truckpinouts.html
Fuel Injector Diagnosis TSB 88-17-11
LIGHT TRUCK: 1985-88 RANGER, F-SERIES, BRONCO
FORD: 1983-88 ******, THUNDERBIRD
1984-88 EXP
1986-88 MUSTANG, TAURUS, CROWN VICTORIA
1988 TEMPO
LINCOLN-MERCURY: 1983-86 LYNX
1983-88 COUGAR
1986 CAPRI
1986-88 SABLE, GRAND MARQUIS, MARK VII, CONTINENTAL, LINCOLN TOWN CAR
1988 TRACER, TOPAZ
MERKUR: 1987-88 XR4TI
1988 SCORPIO
1986-88 E-SERIES, AEROSTAR
ISSUE: Port fuel injected vehicles that have cold hesitation, lack of power, rough engine idle or a surging condition at steady speeds may be caused by dirty fuel injectors. When no-detergent fuel is used, deposits form on the fuel metering surfaces of the fuel injectors. The deposits that form reduce the fuel flow resulting in a lean condition.
ACTION: To correct this, follow normal diagnostics as shown in the Engine/Emissions Diagnosis Manual, Section 2. If you get to a step that instructs you to replace a fuel injector, FIRST try cleaning the injector with the Rotunda Tester/Cleaner, 113-00001. If the condition still exists after cleaning, the injectors should be flow tested to make sure they are functioning properly. If the flow test indicates lean injectors, a second cleaning may be necessary because of severe injector fouling. Refer to the diagnostic chart for step-by-step instructions.
CAUTION: NEVER ATTEMPT TO FLOW TEST INJECTORS WITH THE CLEANING SOLUTION MIXTURE. THIS WILL PRODUCE FALSE TEST RESULTS. ONLY USE CLEAN GASOLINE.
In cases where fouled injectors were the cause of the driveability concern, it should be recommended to the customer that a better quality gasoline be used. The Owner Guide, Maintenance Schedule and Operating Guide address the fuel quality issue.
NOTE: IT IS VERY IMPORTANT THAT THE CORRECT CLEANING SOLVENT IS USED WITH THE ROTUNDA TESTER/CLEANER. THE CORRECT CLEANING SOLVENTS ARE: Power Flush Injector Fluid E6AZ-19579-C & Carburetor and Combustion Chamber Cleaner D9AZ-19579-BA
DO NOT USE Injector and Fuel System Cleaner E6AZ-19579-A
PART NUMBER PART NAME
E6AZ-19579-C Power Flush Injector Cleaner
D9AZ-19579-BA Carburetor and Combustion Chamber Cleaner
digs
