I have an 86 BII 2.9 4WD. 2 Pumps. I just had to change my low Press pump(In-tank). After I changed it, the damn thing would come on after I'd get out, my battery would be dead in the morning, I heard it one night at work and the only fix that I could do at the time was cut the Inertia switch wires and that killed the pump. Next morning I twisted them together started up and went home. This happened for a couple days. One day I go to start and No fuel, and No spark. My code puller gave me a Code 15 No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure). Well my computer is new if that is the fix for this code. And I tried another computer in it to test it and it didn't work. Does anyone have any clues. I'm really getting frustrated with this truck, I would love for this truck to be my toy, but there's not much funding for a toy that i'm dumping time and money into just keeping it running from week to week. This is what I'd replaced so far: the starter, computer, fuel pump relay, in-tank pump, ignition coil, ignition module and temp sensor. I got this truck for free so it is definitely worth it, I think-and it wasn't running when I got it, because some ******* changed the battery connections, and put a grounding wire that should've went on the negative battery side and put it on the positive connector. That took a long time to find. That, in-turn, fried my computer, fuel pump relay and ignition module. This truck only had one owner and has 110k miles on it. Can anyone help, please? Electrics is my worst enemy.
