Wolfpacsrevenge
- Joined
- Oct 29, 2009
- Messages
- 5
- Reaction score
- 0
okay heres the deal I have an 87 bronco with a 5.0 and i can not get it to run properly. the truck sat for a few months and then i needed it when i went to start it the truck fired right up and idled for about 30 mins. Then died out tried to start it again but would start and then die out finally figured it was out of gas put about 2 1/2 gals in it and still nothing messed around with it for awhile making sure fuel was comeing from the low pressure pump in the tank to the high pressure pump on the rail and to the filter and just after the filter and it was then checked the sracheder valve on the rail....no fuel....continued to try and start it but nothing happened...went inside for about 2 hrs came back out and it started on the first try and i let it run for about 20 mins seemed fine.....noticed a leak at the sracheder valve and figured id fix it the next day.......went out to start it again and the same problem no fuel at the valve after about 10 mins it started to leak at the valve and it would start but acted like there was not enough pressure.....put a pressure gauge on it and it didnt even register.... now heres the million dollar question... im pretty sure its a pump issue but without throwing parts at her how do i figure out whats wrong..... please help
( [-o<
