New with a 94 EB 5.8 from NW Missouri
BroncoMatt
NW Missouri
I'm new as of today. I'm a regular on FSB forums, and thought i'd check this one out. I have a 1994 Ford Bronco Eddie Bauer with a 5.8. I've made some mild upgrades to it. the direction i'm trying to point in my upgrading is better fuel economy. i know its almost a lost cause, but it does so many other things so well--why can't i try to squeeze every ounce of awesomeness out of it? right? Anyway my upgrades/repairs/things i've done to it are below and pictures as well.
THINGS IVE FIXED, UPGRADED, OR MODIFIED
new distributor cap
new plug wires
new plugs
new distributor
18" electric cooling fan
4 hole injectors
optima battery
nice head unit with a 10" sub (450w)
33 12.50 15 tires (i know, that kinda goes AGAINST what i'm trying to do)
new clockspring
mpguino installed into dash bezel
new EGR valve
new EVP sensor
new TPS
13.5* timing bump
PSOM recalibrated after tires
seafoamed about a million times
passenger side brake caliper replaced
passenger side wheel bearings and seals replaced
grille replaced
THINGS COMING UP
top removal
spray in bedliner (from rear floorboard back)
fuel pump access door install
bushwacker street flare install
bassani y pipe and 3" single exhaust all the way back
Hedman Full Length headers
PICTURES
yo MATT,
WELCOME!
You have done a lot and from plans, I see that you know quite a few functional improvements incl the fuel pump access.
Btw, our Sponsor here, Jeff's Bronco Graveyard has a Patch Panel for the fuel pump access; 48in. x 16in. for 80-96 Bronco & F Series; $35.00
Have fun!
BroncoMatt
NW Missouri
Welcome Matt, (no pun)
nice looking ride. you can be proud.
help out an old dumb guy.....what is a "clockspring", as it relates to a Bronco?
A clockspring is a "spring-like" wire that is between your steering wheel and your steering column. it's purpose is to be the conductor for the horn, airbag, and cruise control (if you have it). its configured in such a way so that you can turn your steering wheel all the way left and all the way right without losing connection to the horn, airbag, and cruise. It's function is similar to a slipring in a generator or motor (allows current flow through a moving component).
BroncoMatt
NW Missouri
yo MATT,
WELCOME!
Have fun!
Miesk5, you might know me as mkt2488 on FSB. i'm the guy that had the crazy pinging that ended up being a magnetized dizzy shaft... you helped me out immensely and are definitely a Bronco-God.
BroncoMatt
NW Missouri
i forgot about the most important upgrade that i've made, which is remote start. I plan on using the "trunk" button on my remote start keyless entry to roll down the rear window. This is proving to be a little tasking, but rest assured--it will be done.
Oldhenry1
