BroncoMatt
I'm new as of today. I'm a regular on FSB forums, and thought i'd check this one out. I have a 1994 Ford Bronco Eddie Bauer with a 5.8. I've made some mild upgrades to it. the direction i'm trying to point in my upgrading is better fuel economy. i know its almost a lost cause, but it does so many other things so well--why can't i try to squeeze every ounce of awesomeness out of it? right? Anyway my upgrades/repairs/things i've done to it are below and pictures as well.
THINGS IVE FIXED, UPGRADED, OR MODIFIED
new distributor cap
new plug wires
new plugs
new distributor
18" electric cooling fan
4 hole injectors
optima battery
nice head unit with a 10" sub (450w)
33 12.50 15 tires (i know, that kinda goes AGAINST what i'm trying to do)
new clockspring
mpguino installed into dash bezel
new EGR valve
new EVP sensor
new TPS
13.5* timing bump
PSOM recalibrated after tires
seafoamed about a million times
passenger side brake caliper replaced
passenger side wheel bearings and seals replaced
grille replaced
THINGS COMING UP
top removal
spray in bedliner (from rear floorboard back)
fuel pump access door install
bushwacker street flare install
bassani y pipe and 3" single exhaust all the way back
Hedman Full Length headers
PICTURES
new distributor cap
new plug wires
new plugs
new distributor
4 hole injectors
optima battery
new clockspring
new EGR valve
new EVP sensor
new TPS
13.5* timing bump
grille replaced
THINGS COMING UP
top removal
PICTURES
