monza
so i took the plunge.
bought a '75 off ebay.
halled ass out to Las vegas and drove her back to los Angeles.
she's been faltless - and i need her to run all the while i am working on her.
i am new to these trucks - so i dont have the eyes you guys all have.
heres what i know:
bodywork is mostly beat up!
heavy rust in wheelarches - consequently the door posts and doors have sagged and fit v badly (1" drop) - and the whole front fender moves when i lift the door !
hood is fiberglass.
inside has been prof spray lined throughout - so cant tell what the floorpan is realy like.
full hard top - not bad cond
bikini sift top - great cond.
engine is a rebuilt (2500mls) 351 with the 302 rad, fan and hoses up front.
Wild Horses broncoScript covers (with the long T bolt things)
A fkng HUGE Holley street avenger carb - 670cfm
Holley fuel pump
MSD ignition system
power steering from 76 Bronco
HD desert 4 core rad
james Duff power brake
C4 auto rebuilt 4000mls
new BC bronco 3.5' coils
new WH 11pack rear leafs
WH steering stabilizer
all new WH bushings
33" goodrich all terrain - 8000mls
Dont know wheel make - polished alloys - 5 of them - nice
twin exhaust - side exit.
new 12 gal up front
stock 10 gal in back - both work.
also inc a front disc brake conversion - needs spindles to attach.
heres whats wrong:
Brakes pull right big time.
Power assist WAY too high - can do parking lot speeds with 1 finger ! way too sensitive at highway speeds!!
steering 'dead spot' - from 5 to 12 to 5 past twelve - nothing happens - - couple that with the power assist and it can be might worrying at 30+ mph. easy to get the truck 'wagging'.
SPRINGY!!! way too much boing for me - i can set this whole thing off like a jelly with one hand !!
rear lights unpredictable - maybe a new loom needed.
what i need:
recommends for a good shop to take her to in LA - to have her fully checked out.
how do i get the doors fixed - is it a complete new front end plus door posts all round ? - if so should i go fiberglass... ?
how do i **** the bounce ? - new shocks - new springs - lower it all ??
how do i reduce the power assist - is there a valve or something to ratchet down ?
any chance i can quieten her down - slightly - can i attach mufflers that wont choke her up ?
considering its a 351 with that huge Holley on there - she's sloooow - it like there is a slip diff soaking up all the push - anything i should be looking at ?
recommends for buying panels piecemeal - or just go for a new glass tub ?
erm - anything else you can tell me that'll help
any recommends greatly appreciated.
its gonna be a long haul...
will update when i make progress.
Monza
heres what i know:
hood is fiberglass.
Holley fuel pump
MSD ignition system
all new WH bushings
new 12 gal up front
heres whats wrong:
what i need:
Monza
