Atanasd84
put a new 5.0l long block in a 88 bronco. I'm having hard time starting engine. I have set initial timing to 10BTDC BY THE BOOK.
New distributor. Wires. Plug . Wires are going in correct plug and distributor is installed correctly.
I have several issue.
1. Engine does start but runs on 4 cylinders. Bank 1 is not firing at all and fouling plugs with fuel. Only bank 2 is firing.
2.
With KOEO I just noticed when I rotate distributor the fuel pump relay clicks. Then I hear click coming from ignition module on the side of distributor.
I just installed new PCM and Fuel relays. Still relay clicks when I rotate distributor.
Thank you in advance.
2.
