new 1/4 fenders
white night
coloma MI
im looking for 1/4 fenders for my 1995 bronco i have priced them out of JC whitney at 92.99 each the prices is not a problem what i am looking for is a 1/4 that will line up nice and made with good metal. I plan to wheel with it but i want it to look good to. does anyone know where to get a good set or is jc whitneys fenders good to use for a quality
also has anyone sanded the topper smooth for paint I have sanded my topper and plan to paint it the same color as the truck hope that it will SHINE as nice as the truck does ????
stusainte
01085 Ma.
I was looking for the patch panels for my 95 XLT Bronco grave yard had the patch panels for 70.00 a pair wich is just for over the rear wheelwells and I think 300.00 to 500.00 for the full replacement 1/4 panels but thats the cheapest i have found so far and now just waiting for warmer weather so i can replace them Good luck
white night
white night
coloma MI
well i bouCopy_of_Copy_of_mud_005.jpgght my new 1/4 fenders 700.00 dallars later but they look nice and i cant wait to get them on few more weeks as soon as the weather gets nice so i can ride my motorcycle back and forth to work. and I took your advice seabronc and did get them trought JBG. the first set were bent up sent them back and they sent out another set same day so I will be dealing with them more and more just for the service that i recived so to all the people that work for JBG in MI THANK YOU
tail gate is next anyone got one in good shape for sale or know where to get one that wont cost $1000.00Picture_010.jpg
madmax
quakertown pa
I should warn you that you will also more than likly need these they usually rot like ****.
Also, you'll more than likly find that the body tub rotted where the old wheel house joined it. best method to fix that is to pound out a piece of sheet metal for a patch, hold it up against the tub, mark around it with a silver sharpie (they show up better), then cut smaller than that and grind/file/dremil the hole out to fit the patch, then just weld it up.
here's what i did
one more thing, when cutting the spot welds holding the wheel house, center punch and just drill them all the way through from the top, this leaves you holes to plug weld the new one in, and have the quarter panel in place (even if just tack welded) when you go to put the wheel house on, makes the job really easy.
here is a link for a zip file containing pics of what i did, actually the truck has been ready for paint since mid july now, just haven't gotten it done.
also, to prevent it from rotting again, i used a ton of bedliner on the inside of the quarter, and on top of the wheel house, and the body tub, kinda made welding the quarter to the wheel house impossible so i used 25 stainless sheet metal screws (self drilling), thin nylon washers and tons of seam sealer. a couple of professional body guys that gave me paint estimates said that they'd never seen anybody do that, but that it should work great. You wont see the ***** heads with the chrom trim piece in place that im just going to attach with gobs of high temp RTV silicone (the regular harware store caulk gun silicone breaks down at high temps, and you can burn your hand on a hot car in the summer.
white night
white night
coloma MI
i looked at my inner wheel wells and from what i can see right now they look ok but that does nt mean that when i get the 1/4 off that i wont see some bad spots depending how bad they are will detrimin if i patch or replace them thank you for the info i clicked on here for the pics and it took me to a ask.com i would like to cee the pics so please try to resend them if you cant get them to send here you can send them to my e mail it is on my profile and i will give it to you here jaosnstewartkrd@hotmail.com thanks agin
Emmette
