P0141 HO2S HEATER SIGNAL CIRCUIT IS OPEN, SHORTED TO GROUND, SHORTED TO B+ OR EXCESSIVE CURRENT DRAW; Possible Causes & Troubleshooting; possible causes: Shorts to B+ in harness or HO2S. Water in connectors. Cut or pulled wires. Disconnected wiring. Open VPWR circuit. Open GND circuit. Low battery voltage. Corrosion or poor mating terminals. Damaged PCM. Visually inspect the HO2S circuit for exposed wiring, contamination, corrosion and proper assembly.
See my post #5 at
http://broncozone.com/topic/23582-check-engine-light-codes/
PO743 see my post #3 @
http://broncozone.com/topic/22935-92-bronco-randomly-stalls-when-brake-is-tapped/
PO750 & PO755
NOTE: This pinpoint test is designed to diagnose the shift solenoid electrical system only. To prevent replacement of good components, note that the following areas may be at fault:
Electrical — Battery, input sensors, wiring harnesses
Transmission — Internal transmission components, linkage
A1 E4OD ELECTRONIC DIAGNOSTICS
Check to make sure the transmission harness connector is fully seated, terminals are fully engaged in connector and in good condition before proceeding.
A2 CHECK ELECTRICAL SIGNAL OPERATION
CAUTION: Remove heat shield from transmission before removing connector. Remove solenoid body connector by pushing on center tab and pulling on wiring harness. Do not attempt to pry tab with a screwdriver. Reinstall heat shield after service.
NOTE: Refer to the schematic and charts preceding this pinpoint test.
Disconnect transmission connector.
Using a mirror, inspect both ends of connector for damaged or pushed out pins, corrosion, loose wires, and missing or damaged seals.
This pinpoint test is designed to diagnose the following components:
Read more testing @
http://www.thedieselstop.com/faq/9497faq/maint/stj/stj71a20.htm#d
PO443
Vapor Management Valve; miesk5 note; for 1996 Broncos with OBD II, The vapor management valve (VMV) replaces the canister purge valve used in EEC IV; miesk5 note the Vapor Management Valve (EVAP SYS) is located on passenger side firewall, high in our 96 5.0L
http://i647.photobucket.com/albums/uu198/edaminski/96%20bronco/P9050934.jpg pic by Ed.
Read more in my post #2 @
http://broncozone.com/topic/14649-canister-purge-valve/
