Yo HH,
If no moisture is inside;
Lens Fix in 92-96
Source: by BlackSunshine
"Sorry I didn't take any pictures *even though I do have a digital, did this while it was snowing and well...wanted to do it fast*
Years ago, I had an SHO with yellow headlights. My Bronco was showing signs of the onset of this common Ford headlight problem. So, I searched my memory and remembered how I fixed it last time.
Pick up a bottle of CLR
Bottle of 3M rubbing compound
Hairdryer
Distilled water
Remove headlights (on 93?-96) headlights, remove the top screws, (2) 7/16" bolts from the bottom and remove turn signal/park lamp unit. Now CAREFULLY remove the two phillips heads holding in the headlight and then turn back the adjusting for up/down until the headlight pops free. I REPEAT ...be CAREFUL when removing the two top screws. They strip easy. I had to dremel new flat heads into the top to get them back in.
Now, after you remove the headlight bulb (don't touch), pull the unit out ....
Now, go inside and swish about a 1/2 cup full of CLR inside the lens for about a minute. Rinse with hot water until it comes out clear. Now rinse once again with the distilled water to prevent spotting. Dry with hairdryer.
Rub down the outside of the lens with rubbing compound (took me 2 coats to get it nice and smooth). Replace. It made 100% difference on my truck. Good luck!"
Lens Cleaning, general Source: by allpar.com
If you later need to replace the HL ASSY;
Replacement in 92-96; part of Ken's Clear Corners Install; then go to his hot link titled, "Short mostly text tutorial on how to replace the headlights" Source: by Froggmann (Ken P) at froggmann.com
more w/diff details:
Removal Instructions in 92-96
Source: by rugerp89ipsc (mean green) at SuperMotors.net
