Need O2 Sensor Help (not fitting)
winks
Freehold, NJ
I bought a replacement o2 sensor from Autozone tonight. They sold me the Bosch 13953 for my 351W. From what I've read by searching around, this has worked for others, but it is not working for me. The Bosch o2 sensor is not threading in, yet the old one still threads in, is it possible it might take a different one?
I removed my old o2 sensor by heating up the y pipe and the wrenching it free with a large plumber's wrench. The tip of it broke off inside there, but I am not too concerned with it, should I be?
On the old sensor, are the threads x-threaded? If so, get a thread tap; or find a mechanic w/HeliCoil Oxygen Sensor Thread Repair Kit; & do Not spray any silicone based penetrants/**** in there. & do not let anti-seize, grease, **** or oil to contaminate the oxygen sensor prior to installation
So far, the pn look good from var. sources.
including NAPA
Oxygen Sensor
BOSH 13953 $45.49
OEM Type Located Before Catalytic Converter
http://www.napaonline.com/masterpages/NOLM...ensor&VehCode=Y
https://www.rockauto.com/dbphp/mfr,MOTORCRA...ission,5132,You you have have 2, one is for up by y;
Ford pn FOTZ9F472E
http://www.rockauto.com/ref/Motorcraft/Detail.html?DY604.jpg
Ford pn FO3Z9F472A
http://www.rockauto.com/ref/Motorcraft/Detail.html?DY605.jpg
The tip in there will be a prob; get it out if it is in contact w/the new sensor.
W
winks
Freehold, NJ
Thanks for the info. I solved the problem today, it was due to carbon buildup in the threads. I used a tap to clean out the threads, and it was a piece of cake to get in after that.
