need help
buku
im not very car smart so help would be much appreciated about a year ago started my 87 bronco popped it in to gear and it was like some thing was holding the vehicle in place it did this for every dear except revers any ideas
Elmo
Forsyth Georgia
parking brake maybe. or the rear brake shoes stuck to the drum. how long has it been since Bronco was driven ?
Rons beast
Ditto Elmo......some time ago my parking brake release broke. I found out when I backed out of the driveway, and found I couldn't drive forward. I had to drive around the block in reverse, and back it in the driveway. (My neighbors, strangely, didn't think anything of it. That disturbed me)
Fixed the parking brake to release, and the Beast was fine.
Is it AOD? or C6 (some had C6)
Shift Indicator Patterns & Indicator pics (AOD, C6 & E4OD); "...Shifter w/a P-R-N-(D)-D-1 pattern, it is an AOD, note, OD is actually a (D) in a white circle, w/ Trans code T, pic by trigger
Source: by miesk5 at Ford Bronco Zone Forums
P-R-N-D-2-1, shifter pattern, it is a C6
Trans code: K
http://www.broncolinks.com/gallery_images/C6ShiftIndicatorpic.JPG
pic by miesk5 at broncolinks.com/gallery
AOD Description & Operation, Identification Tag, Parts Break-Out Diagram w/Nomenclature, Seals, Rings & Gaskets Locator, Throttle Valve (TV) System, Transmission Shift Patterns, Main Components & Functions, Diagnosis & Testing, In-Vehicle Service, R&R, Cleaning & Inspection, Specifications, & Special Service Tools/Equipment
Could be:
TV pressure too high - check and adjust
Governor stuck or dragging - clean governor
Valve body problem - replace valve body
buku
i havent drove it in about a year. its a manuel 4 speed
Elmo
Forsyth Georgia
So a year ago it would not go forward or you have just tried it and it will not go forward. I would put it up on jack stands-ALL FOUR WHEELS- off the ground. Besure the earth is hard enough to be safe, dont want those stands to topple over while the wheels are turning. Inspect brakes on all four wheels including the parking brake cables ( highly possible that one or both are stuck holding the brake shoes tight to the drums),replace all worn, damaged,missing, or questionable parts. While it is up and easy to work on now would be the perfect time to check oil in front and rear differentials, transmission and transfer case. Once all of this is in dependable working order verify it is in 2WD and wheels are on truck, put vehicle in drive and see if the wheels will turn.
Providing that the rest of the drive train was in decent condition when last parked I would bet this will have it rolling again. Be sure to let us know what you find it always helps to hear "The rest of the story"
79brnco
