need help
rmmk14
ok i have replaced the vacuum booster, the master cylinder, the wheel cylinders, and have bled the brakes 5 times but still have little brake pedal, what else could it be?
Bronc76
How are the rear shoes? The automatic adjusters may not be working causing excessive clearance.
R
rmmk14
the shoes are brand new too. the only thing i havnt replaced was the proportioning valve. would that be the problem?
demon
southeast pa
is it running rough? this is a common problem i have noticed, and mine is the same way. i have to change my modulator. apparently when it goes bad the truck looses mad vacuum and also starts to gag when in gear. Also blows white-ish smoke because tranny fluid gets into the motor
Baltimore773
