Need help identifying this piece. Please help
jasindude1
Doing my control arm am I found this, the stud with threads, the passenger side has the same, but nothing attached? Is there supposed to be a brushing of some sort or did something fall off? Idk what it’s called but if I need it I want to buy it and reinstall. Any help would be greatly appreciated. Thanks!
husmann
Southcentral Texas
Shock absorber mount.  These models had "Quad Shocks" on the front.  You can get by with two, but it will ride better if you have four.
Derek
Yo jasindude1,
In attached quad shock parts diagram;
Item
Part Number
Description
Nut and Washer
Washer
Insulator
5A333
Front Spring Upper Mounting Retainer
Bolt
6
18124
Front Shock Absorber
Nut
Nut
9
18126
Shock Bracket
10
3405
Radius Arm (RH)
3A292
Radius Arm (LH)
Bolt (Must Be Installed in Direction Shown)
13
605921
Bolt
14
58740
Bolt
15
40954
Bolt
16
18A151
Front Lower Shock Bracket (RH)
17
18A153
Front Lower Shock Bracket (LH)
18
N806085
Nut and Washer
19
390678
Stud
20
5A349
Retainer
21
N800895
Nut
22
5310
Front Coil Spring
23
5A307
Lower Spring Seat
24
5414
Front Spring Insulator
A
Tighten to 34-47 Nm
(25-35 Lb-Ft)
Tighten to 18-24 Nm
(13-18 Lb-Ft)
C
Tighten to 34-46 Nm
(26-33 Lb-Ft)
D
Tighten to 60-80 Nm
(44-59 Lb-Ft)
E
Tighten to 433-460 Nm (320-340 Lb-Ft)
F
Tighten to 26-34 Nm
(19-25 Lb-Ft)
G
Tighten to 326-352 Nm (240-260 Lb-Ft)
J
jasindude1
So i just checked my truck, these isnt a hole on the top where the spring sits for another shock to be mounted? is this something that can be modified? I would love to add another shot to the front end
I've noticed that the axles will come with a lower mount even if it is a single shock set up. If you want to do 2 shocks per side you'll have to swap in the correct upper shock mount.
Virgil3rd
