Need Help E4od Tranny Slipping
redneckpunk
Hopkins michigan
help i have a 91 bronco 302cid with e4od trans it slips in all forward gears and takes a second to go into gear anyhelp would be appreciated [-o<
Sounds like time for an overhaul, but try changing the fluid and filter first. If the old fluid looks black or has a burnt smell to it, take the first suggestion.
Shadow_D
Schenectady, NY
If you decide to change the fluid and filter rather than the overhaul, go to your local auto parts store and get some Lucas Transmission Fix. It is not going to cure the problem but it will prolong the transmission's life a little longer until you can get it overhauled.
redneckpunk
redneckpunk
Hopkins michigan
I took it to a shop and they said it would cost sbout 1200 to 1500
dollers to rebuild it . Does anybody know where i can get a replacement
the cheapest i can find it is 750.00 and that is out of state not counting
shipping here to michigan (anyone wanna buy a bronco)lol >:)
I've heard that the Lucas products are first-rate. You might try another tranny shop for a diagnosis, too. 3 out of 4 will want you to overhaul it, but the fourth will tell you exactly what is wrong. I've heard of it costing as much as $2700 for the E4OD for fixxin' it, and $1500 is a decent price. Start scouring the salvage yards for a replacement, or think about swapping to a C-6. Good Luck!!!
Shadow_D
Schenectady, NY
When I had mine rebuilt it cost me $1600 so you got a good price. I do agree with justshootme on checking the bone yards, you might find one there that will work.
redneckpunk
redneckpunk
Hopkins michigan
i tried all the boneyards and nothing but there is a couple out of state for 750 thats my next step or sell the darn thing i still have a 86 bronco too
bob
western pa zelienople
The e4od has gone thrugh some changes sence 89, when you get it rebuilt you should get all of the up dates. This adds alot to the coast. 92 shuld be about half way there, it shuld have some or most of the up dates frome the factory. After 96 or all the up dates the e4od is a strong reliable tranny.
I found this on the net, Ithink they are selling their product but it a nice list of the up dates:
The E4OD has seen many changes and updates since its introduction in 1989, but most later transmissions will prove reliable with nothing more than our ReCal-Pro
ron753
the trans needs to be rebuilt the seals inside the clutch drums are getting hard
when they get hard it lets fluid bypass the pistons in the clutch drums and doesn't create enough pressure to apply the clutches there are 2 types in each drum steel and friction when you loose pressure in the drums the friction starts comming apart
you would be wasteing your time putting a new filter and fluid in i built transmissions for 22 years.
BRETS_BRONCO
Not much of a tranny guy, so does the C6 tranny have 4 speeds/gears or just three and what do you do with the electronic input/ parts if you swap from a e40d to a C6 assuming the C6 does not have any electronics ?
:blush:
S
Stephen Hawk
Guest
BRETS_BRONCO, A C6 doesn't use the electronics so you could just tie the wires out of the way but you would probably throw a check engine light because your computer looks for tranny data to help control engine performance. I don't think it was vital in the 89's but the later ones used it a lot more. All you would need to do to make it work otherwise is install a kick down cable or rod from the throttle. I'm not to sure on the length of the C6 versus the E4OD. He might need a different drive shaft to keep the slip joint from sliping out when the suspension is at full travel or binding at full compression.
S
Stephen Hawk
Guest
Forgot to add the C6 is a 3 speed no overdrive. and the E4OD stands for Electronicly controled, 4 speed w/OverDrive. Three forward speeds and the fourth IS the overdrive
Kingdalt777
