Napa parts
budster 95
Pocano Mountains, northeast PA
I havnt had much time to work on the bronco lately, but i did do pricing on the new pump and tank. The O.E.M. pump price is 349.00. Napa has it for 124.00. I usually like to use O.E.M., but if the Napa pump lasts, why not save a couple hundred bucks. Has anyone installed a Napa in-tank feul pump on a 90-96 Bronco? Thanks for any feedback.
The difference between the two is in the manufacturing tolerances for components and measurements. The OEM part is built to the original factory specifications for that part. An aftermarket part does not necessarily meet those specifications and are just slapped together or use components that do not meet specifications. That being said, buying a non OEM spec part can be a crap shoot, sometimes you win and sometimes you loose. Not that you don't occasionally get a bad OEM part, but you odds are a lot better at getting something that lasts. The majority of aftermarket replacement parts made today are sourced in China and built by what would be considered ***** labor in this country, the reason they are so cheep. I could go off on this, but it is not the subject of the post.
In some cases, you can't get OEM parts for older vehicles and in that case you are stuck with lesser part. An example of that is some of the skins on your vehicle, IE. fenders and quarter panels. In that case you make do with what you get. There is a lot more to be said about this, but I wont belabor the point.
Hope that helps.
yo!
I agree w/you and Fred on OEM parts... esp w/Fuel Pumpos?senders, all sensors, actuatorss, etc.
For that pump, Ford on-line shows it for 95 etc 5.0 & 5.8 as;
9A407 (PFB-4) $429.40 - Fuel Pump 5.8L 351 CID 8 Cylinders; Requires Jumper Harness. See Part Description - Fuel Pump Jumper Harness
& 9A299 Fuel Sender (Gas) $230.07
I usually buy Genuine Motorcraft parts at Amazon Ford dealers; they are VG at delvy and esp pricing; I bought a $150.00 Motorcraft DPFE Sensor for $50.00 with free shipping and no sales tax; Local dealers wanted 150.0 + sales tax; same price & discount for an Idle Air Control (IAC)
Amazon search shows no pumps avail right now, which is unusual; may be a holiday thAng...
Klova Auto Parts lists the pump @ 9A407 $146.88
Our SPONSOR heare in da Zone, Jeff's Bronco Graveyard, shows it as; Item #30255 - New Original Equipment Sending Unit, 1990-96 Ford Bronco3 5/8", Comes WITH pump, OEM sending unit WITH pump. Our Price: $489.00
For body parts, look for CAPA Certified Parts Database Search Results at www.capacertified.org - The Certified Automotive Parts Association (CAPA) is a non-profit organization established in 1987 to develop and oversee a test program guaranteeing the suitability and quality of automotive parts. CAPA encourages competition in the marketplace in the hope that their program will ultimately reduce expense to the consumer and the industry while increasing and assuring part quality
Some results from that List;
Cobra King Industry (Taiwan) - CAPA certified doors & fenders for 80-96
Cross Canada - Bronco & Ford truck body parts, CAPA certified, 78-96 & EB
Discount Auto Parts - parts & accessories - Bronco Tailgate CAPA Certified Part E8TZ9840700A
Gordon - Bronco/Ford truck CAPA certified fenders, door shell, hood, tailgate (83-93 & probably to 96)
Keystone® Automotive Industries, Inc - CAPA body parts, wheel refinishing, etc.
TYC™ Genera. - CAPA certified Bronco head lights
usautobodyparts.com - Bronco/Ford truck body parts; Some are CAPA certified (HOOD *CAPA* F383J E4TZ16612B 1980-1986 $128.25, FENDER RIGHT SIDE (Primed) (Passenger Side) *CAPA* F376H E1TZ16005B 1980-1986 $71.85, DOOR SHELL FRONT RIGHT (Passenger Side) *CAPA* F413D E4TZ1520124A 1980-1986 $126.60, headlight panel, stone deflector; & TAILGATE *CAPA* F4222 E8TZ9840700A 1983-1993 $297.00)
Wheeler's Autobody Supply - Bronco/Ford truck body parts w/Ford part numbers; some are CAPA certified, incl. stone deflector, headlight & tail light assy, door shell, fender, hood, tailgate
Rockauto indicates at times, that a part is CAPA certified; VARIOUS MFR Part # FO1900106; {#E8TZ9840700A, F4TZ9840700A, FOTZ9840010A} Rear gate shell [CAPA Certified] $237.79
GL!
Staff online
digs
