Name that Differential challenge!
Broncosaurus!
Oshkosh WI
Every stock diff I've seen has larger holes where you can take the spider gears out in order to install a mini spool, this one obviously would make that pretty tough, wondering if this is some sort of factory limited slip or something.
Broncosaurus!
Broncosaurus!
Oshkosh WI
No indication, but it does have spider gears and operated pretty much like an open diff to me, I could burn the inside tire in a corner, but in a straight line it spun both.
Best way to tell is to jack both wheels off the ground & spin one by hand. If the opposite tire spins in the same direction you have a limited slip differential, if it spins in the opposite direction it's a standard or "open" differential. By the way, they're commonly refered to as *open* differentials because the differential case is "open" like what you were expecting to find. Now maybe someone else will jump in and correct me *again* <grin> but I think you may have out-thunk yourself by ordering the mini-spool first because it's always been *my* understanding that they pretty much only fit *open* differentials. You don't have an open diff, now maybe you can pick one up at a local boneyard for a few bux (I've done THAT before and it cost me $40). At this point you're probably best off either ordering yourself a regular spool or picking up a junkyard 3rd member w/an open diff. No matter how you cut it I'm pretty sure that what you have won't work with what you have.
im sorry but i dont know *** a spool is or a mini-spool. anyone care to shed any light on the subject for me.
No problem. All a spool is is someting that eliminates the differential all-together. You press the axle-shafts directly into the spool and it mechanically locks everythign together as if there was just a single axle shaft running from one tire to the other. This is kinda rough on roads because whenever you make a turn the inside tire covers less distance than the outside tire (a differential is what takes care of this in street vehicles & that's WHY it's called a differential because it it compensates for the *differential* in tire speeds between the inside & outside tire when you turn. Waay back in the day it was called a "compensating gear" because that's what it did, it *compensated* for the speed differential) A spool does NOT differentiate tire speeds so you'll always scrub a tire on hard surfaces. For off-road only trucks this is fine because the soft dirt or sand will allow one tire to slip and that will take care of the problem. A mini-spool does basically the same thing but it's smaller and can be installed into an open carrier differential saving time, hassles and $$$. A true spool will have the ring-gear bolted to it and the axle shafts pressed into either end. Spools are pretty strong, mini-spools work well in some applications but not all since they aren't as strong and use the factory open differential carrier, a full spool is usually much stronger but it requires more work to install.
This page may explain it to you better than I can: http://www.offroaders.com/tech/limited-sli...fferentials.htm
Broncosaurus!
Broncosaurus!
Oshkosh WI
I have a full spool for it, so I wont need the old diff, looks like she'll be going on eBay as a Trak-lock, they seem to fetch about $200 in used condition. Oh and since it is out of the truck already I can't do the spin the wheel trick and never thought to do it before I took it out, just figured it was an open diff, although the more I think about the times I have been stuck or trying to pull out another stuck truck, power did sort of shift back and forth between the wheels....hmmm...oh well I can't wait to burn the **** out of my no longer necessary 31" street tires :D /emoticons/[email protected] 2x" width="20" height="20" />
