Jeff Ogden
I thought I had rear end issues so it got replaced with one from a junkyard which now needs axle bearings so that is next weeks project,now that its cooling off I noticed the PO has stuck in a cooler thermostat as its not getting warm so while I have the throttle body off to replace it the thermostat will get changed to one with a correct temp. I was finally able to test the rear window defroster and it did not work so off came the access panel and one of the connections on the window is gone so since its getting power back to the tailgate I will try to find a connector and see if I can solder it on,I need to get these things fixed before it gets any colder.
