RetiredAFSpouse
My husband put in a new steering column months ago in my 93 EB with a 302 and E40D tranny. Now getting check engine light off and on. Pulled one code, 626-coast clutch selonoid. I didn't have the issue until the steering column was changed. Coincidental? It will not starting sometimes in park. Won't start in neutral. If I put my left arm around steering wheel pull the shifter towards me, I can start it? Linkage needs adjusting??
Neutral safety switch is only a year old.
I also hear a vacuum leak now and can't find it. When I get it started, Idle goes to 2400 then settles to about 900 and stays. I back out my driveway start to go forward and I hear the whooshing sound. Then it goes away.
All original hoses replaced, vacuum ones too. All these parts are newer, EGR valve, Idle control valve, pcv valve, map, motor craft spark plugs, distrubtor cap/rotor, new throttle body gasket, new lower intake gasket and valve gaskets. My husband refuses to work on it anymore. So I have been working on it. I have a Chilton and Haynes.![1000011124.jpg 1000011124.jpg](https://www.broncozone.com/data/attachments/27/27336-ad8faa3a4a8c0c1abcd71339892ba31d.jpg)
