BigGreenBronco
I am considering getting a throttle body spacer, preformance mass airflow sensor, and installing a cold air intake. Will any of these give me some more horses?
You can't get any colder air than the stock system provides. If you are talking about putting a KN horn on the end of your intake hose verses the air box, and that is all you do, you have just installed a HOT air intake. That configuration takes air from inside the HOT engine compartment. The only thing a KN installation may provide is more air flow but that isn't needed either unless you do something with the engine that requires more flow. The stock induction system can provide all the air your stock engine can choke down. So if you install a KN filter without having made any other internal changes to the engine, it may sound cool because you can hear the air being sucked in, but that is all you get.I am considering getting a throttle body spacer, preformance mass airflow sensor, and installing a cold air intake. Will any of these give me some more horses?
