Manual transfer case with floor shift automatic
OhNo50
Bunnell FL
I have an 86 BII with an automatic tranny with floor shift, push button t-case and auto hubs. I am going to swap in an automatic transmission and a manual t-case out of a 90 BII. The 90 has a column shift. My question is has anyone else made this swap and if so will the floor shift and t-case shifter work together? Also the 90 had manual hubs. Will my auto hubs work with this combination. I plan on replacing them after I recover from the cost of my engine rebuild....lol.
andre
gatineau hill quebec
ARE YOU GOING TO BE ON 4X4 A LOT OR JUST SOME TIME ??
IF YOU USE IT A LOT HERE HOW TO GO
MANUAL HUB MANUAL TRANFER CASE AND IT FIT AUTOMATIC TRANS THE TRANFER CASE AS FOR THE HUB NEED TO CHANGE LOOK BEARING
NUT AND HUBS
THE AXEL SHAFT SOULD BE THE SAME UNLESS YOU HAVE 8,8 INCH DIFF
AND YES IT WILL WORK BECAUSE ONE OF MY BRONCO AS FLOOR SHIFT AUTO MANUAL TRANFER CASE
JUST NEED TO OPEN HOLE ON SIDE OF TRANMISSION LUMP DRIVER SIDE
AND KEEP FRONT AND REAR DIFF ALWAYS HANDY TO HAVE AND CHECK GEAR RATIO SEE WHAT TYPE MAY HAVE LIMITED SLIP DIFF AXEL CODE IN DOOR IF TWO N0# LIKE 41 ORDINARY ONE LETTER AND ONE NUMBER LIMITED SLIP LIKE D4
