Manual Trans Driveshafts
Otto Rex
I am gathering all the parts I need for my 5 speed swap bbut I am not sure if I need driveshafts for a 5speed truck or if I can reuse my old ones. Its a 95 with a 6" lift.
yo Otto
Are you going w/ZF or the M5OD swap?
M5OD
according to Ben; E4OD to M5OD Swap & Parts List in a 93Source: by Havack (Ben P) via miesk5 at Ford Bronco Zone Forums
Drive shaft for the rear. Front can be cut down, but the rear needs to be longer. 3.25 inches longer to be exact. Any longer rear drive shaft will do. You will need to cut and balance it. Plan on new u-joints and if a Bronco a new carrier bearing in the rear to make it balance right.
read thru it
ZF
S5-42 Swap from E4OD in a 95 Source: by Broncobabe (Miss Kitten) at Adventure Offroad
front driveshaft shortened
rear drive shaft lengthened
next on the list is figuring out that damn neutral safety so i can get the truck to fire and building a new rear drive shaft.
we have been able to cut costs quite a few ways so far on the swap as we did alot of measuring and i am able to use the front driveshaft out of the F-250 and reuse the starter from the F250 as well.
S5-42 Swap from E4OD Parts List in a 94
Source: by Franklin (Jeff)
Part Part# Source Cost
ZF S5-42 Ford/Junkyard Used $600
Rebuild ZF: seals, bearings, synchros LP Gear $500
Flywheel E8TR-AA Ford/Junkyard/Call Franklin
New $406
Used $40
Franklin $185
Flywheel Bolts MRG 912 Heinz Bros $8.75
Tranny Bolts 2- 1" Shorter than stock Heinz Bros $2.00
Pilot Bearing AutoZone 7.99
Internal Clutch ***** YL5Z7A5008AA Ford $66.65
Hydralic Hose F3TZ-7A512-A Ford $42.95
***** Cylinder Ford $62.29
Internal Clutch ***** Bolts Interstate Bolt $1.00
Clutch Disc CEN218226 Heinz Bros / Centerforce II $72.25
Pressure Plate CENCFT360049 Heinz Bros / Centerforce II $150.66
PP Bolts 3/8/18-1" Heinz Bros $5.95
Pedals 92-96 F150/Bronco J&T Automotive Used $35.00
Floor Pan 92-96 F150/Bronco J&T Automotive Used $20.00
ZF Shifter/Boot 92-96 F250 w/351 J&T Automotive Used $35.00
Driveshafts: +63mm in the rear, -63mm in the front
Need to use a wire jumper to bypass the neutral safety switch.
S5-42 Swap from E4OD pics in a 90 5.8
Source: by My90Bronco (James, Switch) at http://www.supermotors.net/clubs/superford/registry/4685/21796
GL!
Ford644
