Manual for 302/351W need
stm
Russia, Moscow
I looking for "service" manual for 302/351 W engines (Haynes). Maybe somebody know about it? Where i can download it in pdf or other scanned formats?
What year truck do you have? You can usually find the factory service manuals on eBay. Here is a sample of a set sold on eBay for a 1987 Ford Bronco, F150, F250, F350 http://cgi.ebay.com/ebaymotors/1984-FORD-F-150-BRONCO-250-TRUCK-SERVICE-SHOP-MANUAL-84-_W0QQcmdZViewItemQQhashZitem588da7cedaQQitemZ380333706970QQptZMotorsQ5fManualsQ5fLiterature
The search I used to find this was "ford bronco service manual" no quotes in the eBay search box.
Here is a guy that specializes in factory manuals http://stores.ebay.com/carboagez/_i.html?_fsub=203060012
S
stm
Russia, Moscow
Thanks, I'll look for it on ebay, if it only one sourse.
Russian post and custom is not ideal in delivering. One day i order special mainboard for industrial use, which not selling in Russia. And i wait for it about 2 month, The post parcel leave USA territory in 3 day, and all other time it was "wait on a shelf for something" in Russ custom... :rolleyes:
Thanks, I'll look for it on eBay, if it only one sourse.
Here is what you are looking for http://cgi.ebay.com/ebaymotors/1987-Ford-F-150-250-350-Bronco-Truck-Service-Manual-Set-_W0QQcmdZViewItemQQhashZitem2563c72333QQitemZ160587785011QQptZMotorsQ5fManualsQ5fLiterature .
Good luck with shipping and customs,
Also, put a post in the introduction section of the forum. Include some pictures if possible, we would like to see your truck. If you have a photo processing program make the pictures no larger than 1040 x 768, but 900 x 675 works the best.
I's do as my pal Seabronc advised too;
For now you can get free Vehicle Repair Guides from AutoZone. To Quote; "These Guides have vehicle-specific printable repair instructions covering a large number of models from 1950-2007. Registered users can also keep track of their vehicle's service history as well as sign up to receive e-mailed information about their vehicle, including, Technical Service Bulletin titles, recall notices and service reminders.
You don't have to register online to buy parts from AutoZone"
AutoZone used to use Chilton and now their on-line Guide is "ZNET" that looks just like Chilton
Here are some Excerpt for Cylinder Heads; (I copied randomly)"Remove combustion chamber carbon from the cylinder head with a wire brush and electric drill. Make sure all carbon is removed and not just burnished
Fig. 19 Use a gasket scraper to remove the bulk of the old head gasket from the mating surface
Fig. Fig. 20: An electric drill equipped with a wire wheel will expedite complete gasket removal
Fig. 21: Check the cylinder head for warpage along the center using a straightedge and a feeler gauge
Fig. 22: Be sure to check for warpage across the cylinder head at both diagonals
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0996b43f/80/20/d8/7a/medium/0996b43f8020d87a.gif
Cylinder Head Flatness
When the cylinder head is removed, check the flatness of the cylinder head gasket surfaces.
Place a straightedge across the gasket surface of the cylinder head. Using feeler gauges, determine the clearance at the center of the straightedge.
If warpage exceeds 0.003 in. (0.076mm) in a 6 in. (152mm) span, or 0.006 in. (0.152mm) over the total length, the cylinder head must be resurfaced.
If necessary to refinish the cylinder head gasket surface, do not plane or grind off more than 0.254mm (0.010 in.) from the original gasket surface.
To install: Clean the head and block gasket surfaces. If the cylinder head was removed for a gasket change, check the flatness of the cylinder head and block.
Position the gasket on the cylinder block.
Install a new gasket on the ****** of the muffler inlet pipe.
Lift the cylinder head above the cylinder block and lower it into position using two head bolts installed through the head as guides.
Coat the threads of the Nos. 1 and 6 bolts for the right side of the cylinder head with a small mount of water-resistant sealer. Oil the threads of the remaining bolts. Install, but do not tighten, two bolts at the opposite ends of the head to hold the head and gasket in position.
For 1987-94 models, the cylinder head bolts are tightened in 3 progressive steps. Tighten them in the proper sequence as follows:
Step 1: 50-55 ft. lbs. (68-75 Nm) Step 2: 60-65 ft. lbs. (81-88 Nm) Step 3: 70-85 ft. lbs. (95-115 Nm)..."
GL
digs
